wheels?
Discussion in 'Parts Interchange' started by shurman, May 28, 2002.
  1. shurman
    shurman New Member
    glendale
    1975 2dr. 302 V8
    what size wheels fit on a '75 mav 302, 5 bolt pattern?
  2. Earl Branham
    Lugoff, SC
    That is a loaded question. The bolt pattern is 5X4.5", so any wheel with that bolt pattern will fit on the hub. How large a wheel also depends on the backspacing, which for our cars is about 4.5". I have 15X7 wheels, and have room to spare. Some of the guys on the board have 16 and 17" wheels. Really depends on what size tire, and the ride height you desire. I have the 235X60X15 on the rear, 225X60X15 on the front, and have had no problem. Hope this helps.
    Earl
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Stock backspacing on the 14"x6" rims is 3.5".
    4.5" backspacing on a 14" rim works... I know that much. Done it.
    From there it all depends on rim width, diameter, and ultimately the tire as well.
    Dave
  4. mavericktrick75
    mavericktrick75 My expensive toy
    WV
    If you want to be able to put just about any type of wheel on you can buy adapters for it and you are capible of putting front wheel drive wheels on it.
    It is also possible to get 20's in those big fenderwells.
  5. Acornridgeman
    Wisconsin
    Will 14" clear Granada disc brakes?
    Will a 14" rim work with the Granada brake conversion? I was thinking of running 14" in the front and 15" in the rear.
  6. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Most but not all 14" rims will clear them just fine. I have a pair of 14x6 magnum 500's that won't clear, but the 14x7's will. The contour of the rim is different right behind the hub is the difference.
  7. bigal3000
    bigal3000 Member
    Vancouver, Washington
    1973 Grabber
    How about the stock 14x6 slot mags? Will they clear the
    disc conversion?
