where can i buy a 1971 ford maverick gas tank
Discussion in 'Technical' started by jaxster010, Apr 23, 2012.
  1. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    i have a 1971 ford maverick and i need a new tank cause the film is coming off the inside.and i cant find anything to strip the inside.and if i do strip the inside can i just leave it striped and put it back up.lmk
  2. Moneymaker 1
    Panama City Florida
    A lot of guys use a Mustang tank, it also allows for an easier route for dual exhaust pipes, as for putting it back in without lining it, not recommended, it was lined in the first place for a reason, more than likely to contain rust.
    Just use the search function and all info. you need will be there.
    I bought a 75' tank new and it came with longer straps.
  3. rthomas771
    The 75-77 Granada/76-77 Maverick tank will fit...just use longer strap bolts. You will need to use the later vapor valve because the hole in top of the tank is larger than the early tanks. You can buy the vapor valve through a Ford parts department or online
  4. injectedmav
    injectedmav Member
    Georgia
    If you're doing an EFI conversion AND considering replacing the tank, I would consider doing the Mustang tank conversion with new parts and adding a sump in the new tank. Fuel slosh IS a problem using stock components with EFI and less than 1/2 full. Just a suggestion.:scratchchin:
  5. DC12VOLT
    DC12VOLT Fuel Injected
    Everett, WA
    Cream 1971 Maverick
    How exactly does it cause a problem? Adds another step to my EFI install project...
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    As the gas moves away from the pump it sucks air and you have instant stall. You can get away with it on a carbed engine because the carb is a mini reservoir. another option is to frame mount the pump and have a quart sized reservoir ahead of it. Usually is recommended to have a small low pressure pump close to the tank feeding the high pressure pump.
