Which set would I need for front end of 71 going to disk brakes
Discussion in 'Technical' started by Tlowery643, May 23, 2014.
  1. Tlowery643
    Tlowery643 Member
    Rockmart, Georgia
  2. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    Tom, I would go ahead with the 70-72 kit... only $45 more for the new idler compared to the other kit. Melvins Classic Ford gets $75 for the idler and Autokrafters gets $89.95... JMO
  3. Krazy Comet
    I was less than impressed with the lower control arms that came in my kit, problem is they are the same one Moog now sells...
    For '75-'77 linkage the idler is a off the shelf item, same was used on Granada...
  4. rthomas771
    They were a slight different between the 74 and the 75 disc brake spindles. Don't know what it was...other than the part number on the spindle. But both years used the same ball joints. The difference could be in the calipers.
  5. Craig Selvey
    I have had both sets of disc brakes and they are the same 1974-1977.
  6. cometguy1971
    cometguy1971 Member
    painesville ohio
    1971 mercury comet
    i have a 71 comet and would like front disc brakes,what would swap over?
  7. Craig Selvey
    If you can find them: 1974-1977 Maverick/Comet disc brakes. Optional in 1974-1975.....Standard on ALL Mavericks/Comets 1976-1977. Also Granada/Monarch disc brakes (from the late 1970 Granada's/Monarch's)
    Otherwise, look here: www.DiscBrakeSwap.com
  8. cometguy1971
    cometguy1971 Member
    painesville ohio
    1971 mercury comet
    thanks alot craig ...very very helpful
  9. Craig Selvey
    You are welcome.
