Whick master cylinder to use in swap?
Discussion in 'Parts Interchange' started by rsillmon, Mar 12, 2009.
  1. rsillmon
    rsillmon Sneaky Snake
    Caroline,VA
    Maverick
    Hi, when I go to do the Granda disc brake swap on my 70' maverick which has clutch pedals and drums on it at the moment, do I need to get a different master cylinder or get another stock one? Also, I will be putting pedals from a 73' maverick automatic which has drums and using the proportion valve from the granda. Thanks Robert
  2. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    I think you want the master cylinder for a disc+drum Maverick. Granada one may be the same, not sure, but I do know the drum+drum master cylinder is different.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I used a manual disc/drum master cylinder from a 74-77 Maverick. You will probably need to shorten the pushrod for the correct pedal height.
  4. yellow1970mav
    yellow1970mav Member
    cherry hill, nj
    1970 maverick, 2007 Yamaha FZ1,.
    m/c
    I just did a swap last week. I have a 70 which had manual drum/drum and now has disc/drum. I didn't touch the proportioning valve or m/c. just to see if it worked and so far so good with stopping.:dance::drive:
