who all is still running drum brakes up front?
Discussion in 'Technical' started by maverick7072, Dec 14, 2013.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    my 70 has disc brakes but the 72 grabber I bought has drums all around and im in the process of replacing the wheel cylinders and other things as well.i hear horror stories about drum brakes just wonderin gif there is any tricks to making them work at their best
  2. rthomas771
    Nothing really wrong with drum brakes on a street car...if they are maintained. If you doing a lot of high speed stopping then that is another story. Drum brake do act different when wet so you need to expect this if they are wet
  3. 71gold
    is still substandard for today's standards...unpredictable...
  4. Acornridgeman
    Wisconsin
    Pretty well sums it up. (y)
    My '70 is bone stock and that includes the brakes. I have no fear driving anyplace with drums but I do realize they are not as good as having discs and I drive accordingly knowing their limitations. I grew up with nothing but drums and know how to maintain them properly.
    My '72 on the other hand is built for performance and as such I wouldn't even think of keeping the drums on it. The Granada swap is an easy mod to do and unless the car you are building is a bone stock show car like my '70 is, there is no reason to keep the drums.
  5. bmcdaniel
    I put the V8 in my '70 and ran the original 9" drums for many years. I used to have nightmares about how crappy those brakes were. I had to really stand on them to make any kind of a quick stop. When I got rid of the 9" drums I replaced them with wider-than-normal '70 Mustang 10" ribbed drums. Made a big difference. Eventually I installed '76 discs and it made even more of an improvement.
  6. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    Still have drums and I still hate them!
  7. Krazy Comet
    :yup:
    I drove my Comet home(exactly ¾ mi) and never took it out of the driveway again, now has a set of '69 Torino/Mustang front discs...
  8. yellow75
    Tillamook Oregon
    Still running drum brakes on my car, I like them better at the drag strip for holding at the start line and they have always stopped me at the end of the quarter. Maybe someday I will change them over as the car does not see the strip anymore and driving on the street is far more dangerous
    On my Falcon wagon I am going with 4 wheel disc brakes using Scarebird conversion up front and Crown Vic in the back, I think I would go this route with the Maverick when it gets changed over
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    That right there proves there is something wrong with drum brakes on a street car.
    They also fade much worse during a high-speed stop.
    I really don't understand why some people want to cheap-out and try to justify running drum brakes on the front of their old car.
  10. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    I still do. It is on my list to change over. Eventually......
  11. Craig Selvey
    As much work as you are doing to that car.....I would move that UP the list.
  12. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    True. I would hate to not stop into something.
  13. simple man
    simple man Member
    Bunnell,Florida
    I still have my drum brakes. They're not power. The only thing I have had to do is to adjust them manually. The "self adjusters" don't work well. They will adjust the shoes unevenly. When the shoes are adjusted equally, you will stop straight! :)
  14. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    I still do, with only 26,000 on the car . I use it everyday back an forth to work everyday. Still holds fine. The master cylinder had to be replaced before the brakes did. I still have two wheel cylinders for the front if anybody needs them. My car is a 1974 comet 200 cid.
  15. schroensr
    1975 Mercury Comet
    One more thing, the shoes are still original all the way around the car. That's when parts where really made in the USA.
