Who has one of these this shiny and clean?
Discussion in 'General Maverick/Comet' started by Bob Wiken, Aug 31, 2010.
  1. Bob Wiken
    Fayetteville, Arkansas
    Also, you might guess what it is.
    A. H.D. Shift handle for a Honda Accord
    B. New design for extreme duty windshield wiper arm for the new 2012 Lamborghini
    C. Frying pan handle for 12" aluminum pan from Walmart home/ Kitchens.
    D. None of the above
  2. Bryant
    isnt that the weight that ford hung off the back of some of the trannys in the 70s?
  3. mean_maverick
    yup.......
  4. Bob Wiken
    or the correct answer D, none of the above. It was on my original trans so I figured it can't hurt to have the vibration dampening on this one. I just cleaned it up and plan to attempt re-install (of the trans) tomorrow.
  5. Craig Selvey
    I have ONLY found those on 1968-1969 Fairlane/Torinos I have had. I have NEVER seen one on a Maverick.
  6. Dave B
    Is it needed?
  7. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Vibration Dampener, if it was needed or worked sufficiently it would have been used longer. Some newer cars tried them too, the the 5.0 stangs had the dampener on the rear Pinion and was a better ribber mounted weight. Most people remove them or leave them off if they had to remove it for some reason.
  8. Bob Wiken
    It does make a good handle and it also sits handily on the Parking break cable when trying to wiggle the trans into place.
  9. Cleaver
    Cleaver Member
    MD
    Chel
    I pulled a pan fill C4 out of a 78 LTD II at the Pull-A-Part a couple of months ago that had one of those. The car had what looked to be a fairly fresh rebuilt engine. Honestly, I thought maybe it was some sort of handle a mechanic used to leverage the engine and trans into the mounts from under the car....and just forgot to take it back off when he was done. It looked really "home made". It never occurred to me it could be a factory part.:huh:
    Cleaver
  10. PaulS
    If you have a one-piece driveline (no rubber bushing in it) you can leave it off.
  11. rthomas771
    It looks like rear mount spring. Here is one on a Falcon.
  12. tim keck
    sharps chapel,Tn
    The old Galaxies got 'em too. I've got/had a few '69-70 LTDs, all of 'em had it.
