Why is it missing ?
Discussion in 'Technical' started by 73BlackMav, Nov 4, 2004.
  1. 73BlackMav
    73BlackMav Member
    Arlington, Texas
    1973 2DR Working on HP
    I have a 73 Maverick that was 6 cyl many years ago. Why is the cross member below the engine not there.It did make it easier to remove the oil pan, but I think I should be worried that it is not there.So far all the Mavericks I have seen have this peice, but mine does not even look like it has a place to bolt one up. Any screams of horror or heart attacks from laughter will help..:slap:
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    6 cyl cars did not come with the cross member only the factory V8 cars. All cars had the holes for them though.
  3. 73BlackMav
    73BlackMav Member
    Arlington, Texas
    I guess I need to be clearer...Should I find one to put on. This is not a race car by any means, but I am building it up some..
  4. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    IF you swapped in a V8, you should have installed the lower brace. It stiffens up the whole front end.
  5. maverick1970
    Missouri
    I ran a V8 in mine for over 20 years without one. I agree it does stiffen the front end up.
  6. bmcdaniel
    bmcdaniel Senile Member
    Same here. I swapped in a V8 and drove it for almost 30 years before I even knew there was a bottom brace. Still don't have one. I've heard some people say it makes a difference, others say it doesn't. Maybe someday I'll have to find out for myself. :rolleyes:
