Widest Wheel for the Rear?
Discussion in 'Technical' started by youngmaverick, Mar 2, 2011.
  1. youngmaverick
    youngmaverick Member
    Baton Rouge, LA
    1970 Ford Maverick
    I am widening my wheels and i was wondering what is the widest rim size a 1970 maverick back fender can take. i dont want it to be crazy wide. just wide enough to make the car look more aggresive. any pictures you may have for an example would be greatly appreciated.
  2. Bryant
    the width depends on the hight of the wheel. a 15x8 is the bigest 15 that i belive that you can fit and keep the tire inside of the wheelwell. when you go up to 17s you can go wider because the side wall of the tire will have less bulge than the 15s.
  3. 71GTComet
    71GTComet Member
    Atlanta, GA
    1971 Comet GT(Sold) 1985 Ford SSP LTD
    I've managed to get 14x10's on mine
  4. youngmaverick
    Baton Rouge, LA
    1970 Ford Maverick
    They are the original tires. I think they are 14's.
    71GTComet is there any rubbing or technical difficulties with yours?
  5. baddad457
    Also depends on the back spacing too. That's actually more important than the diameter.
  6. stang01gt
    stang01gt Member
    Spring City, PA
    Maverick
    15x8 with 275-60-15s. old pics, wheels now painted with center caps
  7. elchinelo72
    elchinelo72 Member
    Los Angeles
    71and 72 ford maverick's
    wide tires
    295/50/15 looks cool.:)
  8. 1MTMIND
    1MTMIND Member
    California
    73 Maverick/Comet
    I have 275 60/15s on mine. MT ET drag radials. 1/4 from my leaf spring and my inner fender. I cut the lip in half and slightly rolled the remaining up a little. They are mounted on Weld pro lites with 4 1/2 back spacing I believe
