Will 6cyl C-4 Work With 302?
Discussion in 'Technical' started by PERTANO, Mar 10, 2005.
  1. PERTANO
    PERTANO Too Many FORDS
    San Diego Ca & Rancho Cucamonga Ca.
    71 Mercury Comet, 40 Ford Coupe, 63 1/2 406 Galaxie
    I've got a 71 Comet 250 6cyl with a c-4 automatic. I wanted to swap a 302 into the car, but was wondering if I can use the same c-4 on the 302? I was told there a different c-4 for the 6 cyl. The bolt pattern for the bellhousing looks the same, so why won't it work? Any help would be great.
  2. don graham
    the six cylinder c-4 should work. i believe it's just not as beefy as the one for the v-8. when i look for a c-4 for my cars i don't care weather it came from a 6 or an 8. i just care about the year as they changed from a 24 spline shaft to a 26 spline shaft in 70. that affects which torque convertor you use:) .
  3. PERTANO
    Thank you. I was thinking the same thing, but my cousin swore otherwise.
  4. tim keck
    sharps chapel,Tn
    The 6 trans has 1 less set of clutches than the v8's or so my trans guy tells me.
  5. Jason M
    Jason M Hibernatin for the Winter
    Wingham, Ontario
    1976 Ford Maverick
    you also have to have a 50 oz flex plate instead (depending on year of 302) the one from a 6 cyclinder has 0 oz
