Will a 4.9L from F100 fit in a "73?
Discussion in 'Parts Interchange' started by Raysan210, May 10, 2015.
  1. Raysan210
    Raysan210 Member
    San Antonio, Tx.
    1973 Ford Maverick
    Will a 300ci 4.9L from a 69 ford f100 fit into a '73 maverick? I already have a I6 (I'm not exactly sure of the size of due to being 3rd owner) in there that I'm having issues with and this looks to be a cheaper route rather than getting it rebuilt or overhauled.
  2. Krazy Comet
    It can be done but just about every aspect of this swap screams fabrication... The 300(which AFAIK never came in a 69 F100) is longer, taller and a couple hundred pounds heavier than the small sixes... Nothing just bolts in place, will require custom motor mounts, larger radiator, custom exhaust work and about 14 other etc... Plus when you get it in there the hood probably isn't gonna shut...
  3. Raysan210
    Raysan210 Member
    San Antonio, Tx.
    1973 Ford Maverick
    Ok, I guess it may be cheaper to rebuild it. THANK YOU
  4. 71gold
    sometimes a 5.0 swap is just about a cheap as a 250 rebuild...:yup:
    Crazy Larry likes this.
