Will a C6 transmision fit a 70 mav?
Discussion in 'Transmissions' started by Survival276, Jan 15, 2009.
  1. Survival276
    Survival276 Member
    London United Kingdom
    I'm in over my head and punching above my weight, so if anyone can help me it would be great.
    I thinking about a v8 conversion i have the possibility on an engine and box but will a C6 transmission fit my 70 maverick? Or am I being stupid.
    thanks
  2. don graham
    The c-4 will fit a lot easier. The 70's tranny tunnel is a bit narrower that year. Also the c-4 takes less HP to run.:)
  3. Survival276
    Survival276 Member
    I'll be running it with a 351. And the big thing is I'm getting it for free! what would i have to do to fit it? And is it possible
  4. mean_maverick
    anything is possible, but most likely you'll have to cut the tunnel and make it larger for the C6
  5. don graham
    c-4 will fit behind a 351W with no problems.:)
  6. courier11sec
    courier11sec Member
    Tucson, AZ
    Save yourself the headache and stick with the c4
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    At minimum you will have to fab up a custom crossmember and will have to shorten the driveshaft. These mods would be needed on any Maverick. The 70 has a smaller trans tunnel, so even if the C6 fits later Mavs, it likely won't fit the 70 without customizing the floor pan.
  8. baddad457
    :biglaugh:There are headaches in running a C-4 as well. :biglaugh:
  9. PaulS
    What headaches with a C4? depending on application from stock to fully modified they are a bolt in.
  10. scooper77515
    Sorta on topic...what is the advantage or difference in running C6 and C4?
    All I hear is C6 is heavier, bigger, and parasites off more HP. What else? Still a 3 speed, right? So what is the difference?
  11. PaulS
    It is bigger - everywhere than the C4.
    In stock form it can easily take 450-500 HP.
    The gear ratios are the same.
    It doesn't fit in many of the smaller Fords of the era.
  12. baddad457
    C-4's don't handle torque like a C-6 does. Nor do they like to be neglected over the years. ;) With a C-4 , you "use it or lose it". But in also using it, it's life span is also shorter than a C-6. Sure the C-6 uses more power, but once it's in there, you can forget about it.
  13. scooper77515
    Devil's advocate here...but wouldn't a decently built C4 outlast a C6?
    But, I guess you can build a C6 decently, but with our smallblocks, it seems that a lighter stronger built C4 would still beat out a C6 after calculating weight and size...
    Unless I am missing something.
  14. baddad457
    No. I've had two vehicles with C-4's. Both have had numerous rebuilds. I've had two other vehicles with C-6's. Neither ever had to be rebuilt. One was 38 years old without a rebuild.
  15. scooper77515
    Is the C6 a newer model, or just the "truck" model of the same years?
    I mean were the 4 and 6 made at the same time and the 6 got put behind bigger cars and trucks while the 4 got put in the smaller ones, or was the C4 THE transmission for certain years and then the C6 came along to replace it...
    Sorry so many questions. I just never before got an opportunity to learn this stuff.
