will a crown vic water pump pulley work?
Discussion in 'Technical' started by nickmav70, Mar 9, 2010.
  1. nickmav70
    nickmav70 Nick Maverick
    Dallas, GA
    1971 Ford Maverick
    Got to lookin at the water pump pulley off the early 90s crown vics... it is a 6 rib pulley set up but has two belts without a tensioner instead of 1 belt system like the mustangs... this means it is a ribbed water pump pulley not smooth... does anyone know if this will line up with a early 302 pulley set up but with 6 rib alternator and crank pulleys?
  2. 71gold
    I would think so if the waterpump necks are the same length...and/or spacers...:yup:
  3. 74MAV74
    74MAV74 Member
    pleasant valley iowa
    74' 2 door maverick
    i would think so
  4. nickmav70
    Dallas, GA
    1971 Ford Maverick
    :thumbs2:ill go to the local u-pull-it and take some measurements
  5. 74MAV74
    74MAV74 Member
    74' 2 door maverick
    just pull it off and check
  6. maverick75
    I know a lot of guys run the 86 crown vic pulley setup on these old engines...if its the same as the 86 then it'll work(y)
  7. Bryant
    if it had different spacing than the reverse rotation water pump, just grab the crank pully and brackets for the accessories that you need.
  8. nickmav70
    Dallas, GA
    1971 Ford Maverick
    i am running a regular early model 302 alternator bracket and standard rotation water pump but i want to use a 6 rib instead of a v belt
  9. nickmav70
    Dallas, GA
    1971 Ford Maverick
    just got back from the upullit and it looks like the crown vic pulley is too stubby and would line up too far forward to work with the original alternator mounting location
    however...
    one pulley i found looks promising
    ill let everyone know once i try it out
  10. 71gold
    I still have the set I took off my motor when I went to the electric waterpump...:rolleyes:
    ...:whistle:...
  11. baddad457
    It does. Been there, tried that.:D
  12. maverick75
    Found this info....
