Will all carter rbs carbs. work for my 250?
Discussion in 'Parts Interchange' started by Thomas, Feb 22, 2009.
  1. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    Will all carter rbs carbs. work for my 250, 1973 Maverick?
    My fuel regulator pin broke :( when the carb. was being taken apart for a rebuild.
    Are all models different in some way?
    Will one that has bin labeled for a 200 be correct for my 250?
    Will one made for a rambler 232 work?
    At very least, if I get a really old beat up core.
    Will the pin be interchangeable with other models?
  2. mbg1973
    mbg1973 Member
    MARIETTA, GA
    1973 MAVERICK 2DR
    I cant answer your questions, but i do have one for a 250. PM me if you are interested
  3. Ed Schuhrke
    Ed Schuhrke Member
    Lowell Indiana
    1972 Maverick Grabber w/ 357 W, 4sp. Toploader, 9" zoom 4:11 9" N-case DL POSI, Ladders, Welds 15x3.5 - 15x10 w/ Mickey SS, Electric Royal Blue w/ Black grabber stripe, 5" snorkel on original grabber hood
    stock huh?
    First question: ew why?????
    second: why don't you just fabricate your own?
    or for a little different approach here you go
    IM-30 Four bbl. intake manifold for Ford 240-300.
    Offenhauser four bbl. intake manifold for Holley 390 or Carter AFB to Ford 240-300.
    PRICE: $289.00
  4. Jamie Miles
    That is for the 240/300 "big block" I6's that came in trucks. It will not work on the "small block" I6 that came in Mavericks.
  5. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    the second
    buddy who broke it really went out of his way and tried to weld it, to fix it.
    this didn't work.
    then he tried to fabricate one with a small lathe, and the pin would continualy break.
    I was sure the cost of the pin really wasn't worth all that time and trouble.
    he put the carb. back together with the broken pin. I would imagine this is not going to work right.
    we put it on the engine, and yes it runs poorly, it worked poorly before we even started on the carb.
    The car has bin sitting for years, the carb is only one thing wrong with it.
    I appreciate the help.
  6. rthomas771
    That's the same carburator that came on the 74 250
