Will Granada front coil springs fit my mav?
Discussion in 'Technical' started by joshyx, Oct 2, 2007.
  1. joshyx
    joshyx Member
    El Centro,CA
    1974 Maverick 250 I6
    I just got a 78 Granada with a 250 that im in the process of swapping into my 1974 mav...I was just wondering if i could cut the granada coils and throw them in my mav...i cut my stock coils on my mav and I have a perfect stance with my 200, but with the 250 being about 50lbs heavier i'm sure im gonna start rubbing(i do already sometimes with the 200 in there)...let me know....thanks...if they dont fit, I think i have a few options lined up with some members on here...
  2. Taxi Rob
    Taxi Rob Member
    San Diego, CA
    1972 Comet 200ci coupe
    Cutting the springs? Hmmm...
    You could also try the old-school method of lowering, heating the springs. I'm sure there are some tutorials online somewhere. Or maybe you could switch to regular 200 springs and start over?
    P.S. when asking about sway bars, someone told me to check out Esco Springs and Things? Ever heard of them? Lots of Ford shops in Escondido. Also check "parts for sale" on craigslist, there's a Mustang shop always advertising there. Ever attend any shows/meets in SD?
  3. Sam M.
    Sam M. Just a nobody
    Southern NJ
    You could try the Granada springs, but before you do, there are other things you can do to lighten the front end, namely relocating the battery to the trunk and swapping the big bumper for the small one. You'll transfer a lot of weight that way and can use the springs you have. For what it's worth, I don't think the extra 50 lbs of the 250 is going to make much difference.
  4. MikeyBoy
    MikeyBoy Member
    West Hills, California (Southern Part)
    1970 Ford Maverick
    u should get mustang springs, u can get them rated for the heavier engine, and cut those
    then u can get the drop with a stiffer ride, so less rubbing
    also heatin the coils is unsafe and a bad choice
    talk to derek, he sold me my springs
