Will Not Start
Discussion in 'Technical' started by SuperByelich, Aug 24, 2007.
  1. SuperByelich
    SuperByelich Jesus Is Lord.
    Chincoteague, Virginia
    1971 Maverick Grabber
    Hi all,
    My Grabber will not start once again. This is the third starter, and i'm getting frustrated. I thought it was burning them up, but it does not seem to be the case. I talked to a friend and we ended up taking the starter I had in before this one and hooking it up to a battery, and it spun! So my question is what could be the issue? I used my jumper cable to bypass the solenoid and do a direct power to the starter and I heard it like "clunk" almost as if it's trying to spin but won't. What could this be? This is the third time it's done this to me and i'm at wit's end!
    thanks,
    Jason
  2. Maverick Man
    California
    is the solenoid new... got an amp meter? if so check the voltage on the starter side.
    btw buy NEW starter... screw the rebuilt ones they almost always go bad within a year!... opps i'm sorry they call it remanfactured...lol!
  3. Mavman72
    Check your ground cable.Heck check both cables/connections at battery,solinoid,starter.Sounds like you are not getting proper voltage/amperage through the start circuit.Do a voltage drop test on the cables.You may have a bad one.
  4. SuperByelich
    yes, but why would it not turn over going directly from battery to starter?
  5. SuperByelich
    I hear it engage, but its like it's stuck
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I am with Mavman 72,, what he said.
    Dan
  7. Mavman72
    Bad ground will cause it.
  8. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    Make sure the wire going to the starter is tight, and on the correct side.
  9. blugene
    New cables are CHEAP and look cool... The problem is probly at the block on the ground cable. I have seen a battery that would cause this same thing... and long story short, I have seen a trans cause it too. Of course it was the rebuilders at Eagle Transmission in Mesquite TX that caused it and charged me alot of cash. :mad:
    Let us know what you find.
  10. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Even if your battery terminals and posts are corrosion free.......if they are gray in color,clean them. They should be silver-looking:2cents:
