Will stock 14" rims work with disk brakes?
Discussion in 'Wheels and Tires' started by David74maverick, Apr 17, 2010.
  1. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    I have the granada front disk conversion and the explorer rear disk conversion done but the thing is I still have my origenal 14" spare... will it work if I have to use it? Or do I have to get atleast a 15" riim for a spare? I'd appreciate any and all info I can get. Thank you.
  2. justin has a 74
    kentucky
    it should, i have the original granada 14 inch rims with my granada disk brakes.
  3. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    yea they will work just make sure the center bore of the rim is big enough for slide though
  4. CaptainComet
    Factory 14x7 Magnums get a bit close to the caliper. I had a rubbing problem due to a rough weld on the wheel. 14x6s are fine, and 15x7s are no problem.
  5. David74maverick
    Arizona
    I don't know how wide the origenal rims are that run the 195/75-14 tire... this is just a spare but its 36years old so I'm debating on either putting a newer tire on it or just get a differant rim & tire.
    Any fitment experiance with a 14" rim and the explorer rear disks? thanks
  6. CaptainComet
    Food for thought ... I scored a smaller spare out of a mid-80s LTD. It is T125/80/16. It takes up half the trunk space that a full size spare does. You keep it pumped up to about 60psi IIRC.
    Grab the molded grey felt cover that came with it too. :thumbs2:
