Will They Settle?
Discussion in 'General Maverick/Comet' started by Crazy Larry, Mar 27, 2015.
  1. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Obviously, I'm gonna have to wait & see, but I'm just looking for opinions based on your experience.
    I finally installed my new leafsprings that I bought from ESPO last fall. They are just stock replacement 3-leaf, but the car has quite a "rake" now, as if it has air-shocks (but it doesn't). Do you guys think they will settle over the next couple of months?
  2. 71gold
    do you have new springs on the front, if not they may be saging?
    Static likes this.
  3. mojo
    I doubt u will see any meaningful settling. I don't have ESPO's, but installed General springs abt 4yrs ago and don't see little if any settling.
  4. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    I have a set sitting in my garage because of the same issue. There is no way they will settle enough to even them out. I ended up switching to caltrac mono leads and they are tall to but not as tall as the replacement 3 leads.
  5. Krazy Comet
    I doubt they'll settle to your liking...
    The tail was a little saggy on my Comet so I stuck a pair of air shocks on it, with about 30 psi in them it's just the right height...
  6. Craig Selvey
    This is 4-leaf Espo's. They haven't settled...but the height looks just right.
    Let's see some pictures of your's.
  7. Cruzin Illusion
    1972 Grabber
    Here are the 3 leaf replacements from Espo.
  8. Cruzin Illusion
    1972 Grabber
    From the rear.
  9. Rasit
    Rasit Member
    SE Pennsylvania
    Hard to judge the stance from those angle shots. But if the stance is good maybe you should consider filling up that well with rubber. What size are those rear tires (diameter )?
  10. Cruzin Illusion
    1972 Grabber
    245/45/17's
  11. Cruzin Illusion
    1972 Grabber
    Here is another profile picture of the 3 leafs.
    To the original poster does it push your axle forward so you axle doesn't look centered in the wheel well?
  12. mojo
    Those springs are ridiculously high, no matter the viewed angle. My 4 leaf Generals were nowhere near that high even though the ride was intolerable AFAIAC. I removed the bottom leaf and only lost between 1/2-1". That car is/was so ass-end high - it might give any rear passengers nose bleed.
  13. Mavman72
    Springs settle when they are worn out...
  14. Cruzin Illusion
    1972 Grabber
    They don't settle 4-5 inches.
  15. Mavman72
    No they dont and...Who wants worn out springs.
