I just want to double check that I have it right. This is a picture of the distributor that I got to work with my roller motor. The three wires on it are the same as my original distributor so that is no problem. But, it has the newer style male connection cap. I got the correct ignition wires to run from the distributor to the spark plugs. My question now is regarding the coil (it also needs to be male style connection). I have the coil from the 1995 mustang that my engine came from (also pictured). Can I just plug the + and - wires that went to the coil in the original maverick set up into this coil (it has two connectors marked +and-) or would there be more wiring involved to run this style distributor and coil? PS The car has electronic ignition. Thanks for the help
