Window help
Discussion in 'Technical' started by gdemopesq, May 31, 2008.
  1. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
    I have a 4 door and autocrafters doesnt help too much with what I need. So your help is appreciated. I need weatherstripping for 4 doors. I also need what I think is called "beltline" for the 4 doors. Beltline I believe is that rubber piece that attaches to the door at the lowest point of the window so water doesnt roll down the window into the door. Any good soureces out there for the doors?
    Also what do I need for the front and rear windows? Rubber and clips? Any good sources?
    Thanks
  2. Craig Selvey
    I "think" you can get two door beltline and cut them down for a 4-door....but I have never looked.
    Nobody makes 4-door weatherstrip.
  3. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    You can use a 2 door beltline. You need to buy 2 sets and cut them down. Also when you do this cut the metal clip off and they need to be glue in. I had someone do this on mind. They work good.
