windshield leak question
Discussion in 'Technical' started by jerrymal, Sep 30, 2011.
  1. jerrymal
    jerrymal jerry
    Brownsville tx
    1973 maverick
    Just got my windshield gasket replace but still got small leak. My question is should the windshield be remove to put some butyl chaulking cause no sealant was put under windshield or can windshield be seal with butyl chaulking between the gasket and body without removing the windshield.
  2. mercgt73
    Are you sure the windshield is leaking and not the cowls? Not trying to insult, would hate to see you go to the effort of sealing the windshield if the problem is else where.
  3. jerrymal
    jerrymal jerry
    Brownsville tx
    1973 maverick
    No the cowls are fine ,I can see the water leaking from the windshield.
  4. sgaugeguy
    sgaugeguy Bob Kraus
    WILLIAMSTOWN NJ
    I had my glass seal replaced twice (@75. each plus labor) and it still leaks. The glass people just don't know what they are doing when it comes to vintage cars. I am now just living with the leak because I don't want my car mucked with again. Im afraid they will scratch it.
  5. Craig Selvey
    When you replaced your rusty roof with part of a Cadillac roof, did you have to do any work in the area of the pinch weld around the windshield?
    You should be able to reseal the windshield with the glass still in place.
  6. rthomas771
    The glass shop that did my windshield pumped sealer between the car and rubber and between rubber and glass after it was installed. The also sealed the groove where glass sits in the rubber before installing. In other words the used a lot of Butyl sealer.
  7. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
  8. Resto
    Resto Benders Evil Twin
    Yuma AZ
    If you want something done right... Id contact the shop that did the work and ask for my money back.
  9. gmatthew76
    gmatthew76 Member
    Freeport, Fl
    1976 2 dr Maverick, 1977 2dr Maverick,1998 Ranger, 2004 Focus Wagon
    Flowable Sealant
    Try some flowable sealant. I used a tube of it to temporarily fix a badly leaking gasket until I could get a new gasket installed. That was 6 months ago. and it hasn't leaked a drop since.
    Good luck.
  10. jerrymal
    jerrymal jerry
    Brownsville tx
    1973 maverick
    That area wasn't touch.
  11. 71gold
    Butyl sealer...is the key word...:yup:
    if they used the late model sealer...it will leak...:cry:
  12. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    I agree, these new shops don't know what to do as most don't work with gaskets much at all.
