Windshield replacements and tint removal.
Discussion in 'Cosmetic' started by Memphis901, Oct 26, 2014.
  1. Memphis901
    Memphis901 Member
    1971 Ford Maverick Grabber
    The glass on the sides are a little scratched up and also has tint that is too dark that needs to be removed.
    Front windshield is scratched where winshield wipers go.
    Anyone know where to get a replacement windshield that's in decent condition?
    What about tint removal without scratching the glass?
  2. 71gold
    :Welcome:...:Handshake:
    about any glass shop can get you a new windshield. Melvin's has the new seals.
  3. Drew Hierwarter
    Drew Hierwarter Member
    Kingsport, TN
    1976 Comet
    Tint removal is not that hard. Use a single edge razor blade to gently lift the film at one corner. Then slowly peel it back. If you're lucky and work slowly it will come off in just a few large sheets. Once the film is off you can clean off the adhesive residue with some lacquer thinner and paper towels.
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I don't know what kind of window tine you've removed, but I've never seen it come off that easy.
    The best way to remove it is with a steamer. Of course you willed a razor blade to lift the edges, but don't use it for "scraping", as it will scratch the glass. Expect it to take as much as a half-hour per window on the side glass, and longer on the back glass.
    Russell likes this.
  5. yellow75
    Tillamook Oregon
    I had the pleasure of removing tint once not an easy task, I used a heat gun trying to not heat the glass real hot and then used acetone to soften and remove the glue, the adhesive remover stuff works good also. I have heard about an eraser wheel that you mount to a drill for removing old decals but dont know if it would be safe to use on glass
  6. 71gold
    I used an eraser wheel once on some decals on my new truck...:thumbs2:
    I would think it being safe on clear coat that it shouldn't damage the glass.
  7. Drew Hierwarter
    Kingsport, TN
    1976 Comet
    I don't know what kind of tint it was either but, given the low quality of some of the other things that were done to this car by previous owners, I would guess it was pretty cheap.
    But, trust me, it really did just peel off.
  8. yellow75
    Tillamook Oregon
    They make a tint that is a static stick type that is considerably thicker and is called peel and cling it really easy to take off perhaps that is what is on the car
  9. Memphis901
    Memphis901 Member
    Ah ok. I took it to a tint shop and they said to wait until a hot day came.
  10. 71gold
    a heat gun will make any day a hot day...:yup:
    Crazy Larry likes this.
