There's two connector that realy buging me. There's two who are very near and got brown or dark red wire. they stop near distributor. An other one is the one between the windshield washer bottle and shock tower on driver side. cause the connector have been cut and I realy don't know what wire go with other. If I remember there's two with, two red-lightgreen and an other red with strip on but too mess up to distinguish the strip color. That's it David
Does you car either crank or not crank in gear, neutral or park. Could be that circuit. The car should crank in park and neutral but not in any gear position as determined by the transmission switch position.
I don't thing but any way the neutral safety switch is plug into the column and I install a floor shifter so the switch doesn't matter at all but I will plug it don't be worry
