Wiring socket disconnect
Discussion in 'Technical' started by FinnMav, Mar 9, 2019.
  1. FinnMav
    FinnMav Member
    Finland
    ´74 Maverick 2dr
    Hi guys!
    Im tearing my '74 mavs enginebay apart and wirings are all out except that main connect in the firewall.
    I tried to pull it but it seems to be very tight fit.
    Is there any screws or pins or something that is holding it down? Or am I just too weak :D
    -Finn
  2. mojo
    Have u removed the screw from inside the firewall that seperates the outer from inner half?
    The fuse block is a two piece affair.
  3. FinnMav
    FinnMav Member
    Finland
    ´74 Maverick 2dr
    No, I havent. What kind of screw i should look for?
  4. Krazy Comet
    It's a 3/8" bolt head in center of block, can't miss it. After fuse box is unplugged, a couple plastic tabs must be slightly compressed, they hold firewall side of plug in place.
  5. FinnMav
    FinnMav Member
    Finland
    ´74 Maverick 2dr
    Millions of thanks to you !! :bowdown:
    -Finn
  6. mojo
    Did U find the screw and get fuse block removed? Are you re-wiring the entire car?
  7. FinnMav
    FinnMav Member
    Finland
    ´74 Maverick 2dr
    Yes, fuse block is out.
    I think im going to repair the old enginebay harness. Actually, my co-worker will do it, he is a car enthusiast and electrician. My knowledge of electric is poor: all I know about it is that it is blue and it hurts :LOL:
  8. 71gold
    is he home or auto electrician?
  9. FinnMav
    FinnMav Member
    Finland
    ´74 Maverick 2dr
    Both :happy:
    71gold likes this.
