WOOOOOOO!!!! Good things do happen!
Discussion in 'Technical' started by justin has a 74, Aug 27, 2010.
  1. justin has a 74
    kentucky
    Its amazing what a hot tanking can do to a pair of heads. Ill be burning off my new tire in no time. (now that my valve train geometry is right)
    Things do happen for a reason. Car broke down and i had the money.
    100 for gaskets + 150 for the heads and motor + 40 for spark plugs + 80 for cleaning = 370
    vs
    280 for new seats for bigger valves that were on heads + 40 for pushrods + 40 for sparkplugs + 100 for gaskets + 30 bucks for 4 new valves on the drivers side (they were short) = 490
    yeh, i would have had "gt40 heads" but i dont really care right now because i saved 120 bucks!!!! Dance banana man, dance!
    :bananaman:bananaman:bananaman:bananaman
    if my math is right:huh::D
  2. Dave B
    So is it back together yet???
  3. rickm
    rickm Member
    Owosso Mi
    I've always wondered, when you paint heads like you did should you use a primer first or just the paint ?
  4. justin has a 74
    kentucky
    Putting it together today.
    Dont really know, i just paint them...
  5. 71gold
    use...engine paint...no primer...:yup:
  6. rickm
    rickm Member
    Owosso Mi
    Thanks Will do
  7. Dave B
    Is it done yet???
  8. don graham
    Inquiring minds want to know.:hmmm:
  9. justin has a 74
    kentucky
    Im working on it, didnt have any thread lock!
    Got one head on right now and one header attached. Going to install plugs and work on the other side.
  10. Dave B
    What do you need thread lock for??
  11. justin has a 74
    kentucky
    For the head bolts.
  12. Dave B
    Really, I've never used it.
  13. justin has a 74
    kentucky
    Im just taking precautions. Im a worrywart :D
  14. 302-72-mav
    302-72-mav Member
    sactown CA
    every thing on a vw bug
  15. maverick75
    Follow the stock specs(65-72 ft lbs) and Lighty oil the threads . If you use thread lock it increases the friction which prevents an accurate measurement of tightness.
