worn shock ?
Discussion in 'Technical' started by mzix, Mar 6, 2014.
  1. mzix
    mzix Member
    zx2
    Hey Folks
    I've been looking for my first Maverick and have received some photos of a Comet for sale. The part highlighted by the red circle---is this simply a worn out shock absorber bushing ? Or could it indicate a bigger suspension problem ? I also realize that the export braces have been removed
    Thanks for any input
  2. Dave B
    It's the shock, probably needs to be replaced. Depending on the car, you'll probably be in for a front suspension rebuild at some point.
  3. 71gold
    I see a new Champion radiator...:thumbs2:
    I like the short...hood prop...:yup:
    check the...cowl lip...may be issues there.
  4. Craig Selvey
    FYI: Factory on all 1976 and 1977 Mavericks/Comets.
  5. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Weird, my 76 parts car has the same prop rod my 73 has. Is it like a split year thing?
  6. RUBEN
    RUBEN Member
    Pala, CA
    1976 Ford Maverick
    My 76 also has the regular long prop rod in the front
  7. Craig Selvey
    Yes....some 1976's had the longer prop rod.
  8. mojo
    The shocks needs replacing. I had the same problem. I can't say nothing else is wrong w/ the suspension , but I do know the shock bushing is deformed. The cheaper shocks are made so the bushing can slide in bushing housing. I replaced them w/ KYB'S and the difference was apparent right out of the box.
