Wow,,,,I learned some thing new,,,
Discussion in 'Other Automotive Tech & Talk' started by JOEXR793, Mar 2, 2008.
  1. JOEXR793
    JOEXR793 Member
    Cleveland Ohio
    I have a 1976 Maverick Stallion, and 85 More Mavericks and Comets in Inventory.
    Went to my buds house today,, he has a 4 car garage, In one space is a 69 Mustang, has prob 80,000 miles on it,, his Wifes car,, The cement floor under it is spotless not a drop of oil any place,, the next car is his pet project 73 Olds Cutlass, The floor under it is stained and has a basin under the engine,, Next car is his 2005 GMC 2500 4X4,, Looks like the Exon disaster under it,,, Now he is a Die Hard Chevy man,, and I had to ask,,, Whats with the oil slicks under the GM,s,,? His reply: Thats just sweat from all that Horse power,,,(y)
    I never knew that,,, Hmmmmm
  2. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    HA HA HA!!!!
    More like sweat from fear of the ford sitting so close!!!!
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
  4. scooper77515
    I like that!
    Wish it was dry under my car...still need to do some serious work to the transmission to get it to stop leaking. Never had any engine oil drips, ever.
  5. actionrpm
    actionrpm Differential specialist
    western pa.
    '70 mav. '40 Ford Pickup '72 Bronco '06 SuperDuty V-10
    My buddy was looking at my Ford Blue motor and said Chevy paints theres black to hide all the oil leaks,and he's a Chevy guy!
  6. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    GM's don't leak oil, they mark their territory, some do it more often than others :D
  7. Jamie Miles
    Damn, I'm going to have to remember that! :biglaugh: I am now on my 5th C4 transmission between two Mavericks. I have yet to have one that doesn't leave a puddle of trans fluid under it.
  8. bmcdaniel
    bmcdaniel Senile Member
    Horsepower? You mean horse$hit.
  9. PaulS
    You should rebuild one if you want a C4 that doesn't leak. When you replace the front and rear seals with new bushings in place and use the quad ring on the kick-down lever, and drill the relief hole for the manual lever when you replace it's seal and put new o-rings onthe dipstick and speedo insert, there is no place to leak anymore.
    The two places that leak on C4's are the kick-down shaft and the rear seal. If the rear seal is leaking it needs a new bushing and/or to have the slip yoke repaired with a speedy sleeve. If the yoke has a groove where the seal rides it needs a speedy sleeve. If there is no groove then it needs a new bushing and seal. I like to replace all the bushings in the C4's that I build. I haven't heard any complaints about them leaking.....
  10. Slantsickness
    Slantsickness Member
    Tucson, Az
    1975 2 Dr.
    Yea, if you got a chevy and it 'aint leaking, you had better put more oil in it quick. If they 'aint leakin, they 'aint workin, (at least not for long)
  11. obmav
    obmav Greg Garrison
    olive branch, ms
    partial owner/ 1973 Maverick
    speedy sleeve:huh:
  12. PaulS
    The "Speedy Sleeve" is a very thin stainless bushing that is sold with its own installation tool. It slides over the outside of a shaft (or yoke) to provide a new surface for the seal to ride on. It is an inexpensive way to make a worn part serviceable for years to come.
    There is one mistake that people make when installing their transmissions that I should menstion. You have to lubricat the slip yoke and torque converter hub when you install them because they can run for over five minutes before they get any oil. I have seen new tiorque converter seals burned up (no sealing lip on the seal at all) after just a few minutes of running. They will leak almost from the start. My rebuilds are sent out with a heavy assembly lube (made for automatics) on the seals and a set of instructions for the installer to use Vaseline to lube the torque converter and slip yoke as they are installed. If they forget, at least the seals have a fighting chance with the lube that I use during the build.
