XE266HR and power brakes
Discussion in 'Technical' started by sixtyfour, Jun 24, 2010.
  1. sixtyfour
    sixtyfour SixtyFour
    Cometland, CA
    1964 Comet
    Is anyone running a Comp Cam XE266HR with power brakes? Any issues with not enough vacuum? I'm running a 302 HO with the cam, Edelbrock heads and RPM intake.
    Thanks!
  2. maverick75
    The Maverick booster needs at least 17in.hg to function properly.
    just so you know (y)
  3. sixtyfour
    sixtyfour SixtyFour
    Cometland, CA
    1964 Comet
    [FONT=arial,helvetica]My aftermarket booster requires a minimum of 15 pounds engine vacuum at idle for maximum stopping power. I think my stock 302 puts out 18 pounds.
    [/FONT]
  4. baddad457
    I ran a Z303 with a Ranger booster and had zero problems. Ditto with a Vic Jr fed by a B303. You shouldn't have any problems.
  5. bmcdaniel
    Not running power brakes but I'm running that cam with Ebrock heads, etc. Have 15-16 in. of vacuum at idle. You'll be fine.
  6. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I think that's the cam I run, and it was fine.
  7. sixtyfour
    sixtyfour SixtyFour
    Cometland, CA
    1964 Comet
    Thanks to all! I am looking forward to running the booster again. I miss the extra stopping. Here is a photo of the motor build. Pretty stoked!
