You Guys With Fat Tires . . .
Discussion in 'General Maverick/Comet' started by Crazy Larry, Feb 11, 2015.
  1. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    There's been a lot of discussion here lately about tire & wheels sizes for these cars.
    My question is for all you guys running wide tires on the back (and still running leaf-springs):
    How close are your tires' sidewalls to the leaf-springs? When you have time, if you'd take a measurement, I'd be interested to know (along with the tire sizes you're running).
    I'm just curious of what the "sweet spot" for maximum tire width is between the body and the leaf-spring. The rest is just a matter of calculating the wheel backspacing so that the tire sits where it needs to.
    Static likes this.
  2. Bryant
    275/45-17. they have about 1/2 inch of space between them and the leaf spring. when i started autocrossing i noticed rub marks on the spring from the tire. it took extreem corning loads to make that happen. i dont have the wheel back spacing available right now.
  3. JoeB
    JoeB Member
    Stowe, PA
    71 Maverick, 72 Comet GT
    255/60-15 BFG T/A...15x8 w/4.5 backspace..gave me about 5/16 clearance to leaf...a little close,but the car isn't being built for twists and turns...4.25 backspacing would have been perfect...the BFG is a wide tire 10.2" section width versus
    Cooper 255/60-15 has a 9.73" section width...the bump stop will need some grinder lovin on the tab that may try to eat your inner sidewall
  4. 71gold
    275/60/15s...raised white letters to the inside and no rubbing...some motorXing)
  5. mavgrab302
    Cooper 255/60/15 4.5 back space. I had .25 of clearance so I added a .25 spacer for a little wiggle room... Also removed bump stops...
  6. scooper77515
    I find it interesting that all of our cars seem to be able to take different sized max tires. I ran 245/60-15 no probs. Went up to 255/60 and cannot get my pinkie finger between springs and tire, and the fenders rubbed on hard takeoffs (not rubbed...cut into the tire sidewall). These were both BFG T/As. I have rolled the fenders since. There is no way I could get a 275 on the back of mine.
    Here is the space I have left with 255s installed.
    And attached photo of the sidewalls after a few launches.
  7. CaptainComet
    Scooper,
    Tire brands run different section widths for the same numeric sizing. BFGs run fat in their given sizes. I have 265/50/15 Coopers on mine, and a 245/60/15 BFG is less than 1/2" narrower. Strictly speaking, that should be more.
    By the way guys .... I have a new job, and after 30 years I am back in the TIRE BUSINESS. I am a commercial account rep (not my official title, which is a bit confusing) for American Tire Distributors ... the biggest wholesaler in the country. We stock over 20 brands, all the majors. Neat job, very happy! I have a lot of catching up to do... lots of changes over the years.
    Static, Crazy Larry and Dave B like this.
  8. scooper77515
    So, based on Jeff's response, you cannot just ask "How big?" as much as "How big in Brand X?" will fit...
  9. 71gold
    width of rim has a lot to do with it also...
  10. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    Yes, the width of the rim does make a big difference. I am trying to decide whether I am going to use my 15" rims that I have restored or buy new 17" rims.
    Can you guys (bryant, JoeB,Frank, Mavgrab302, scooper and Captain) chime in and tell us what width your rims are please? :huh:
  11. JoeB
    JoeB Member
    Stowe, PA
    Rim is a 15x8 with 4.5" backspace...haven't mounted them yet due to bump stop...I will run a1/4" spacer until I get the 9" in
  12. scooper77515
    15X8 with 4.5 BS also.
  13. JL Mav
    JL Mav I almost made it to Lake Tahoe
    Douglas county NV
    72 Maverick, 68 Mustang, 61 F100 unibody
    I had 15x 8 with 4½ backspacing with 255 60 r 15 tires and I would only rub in the fender well when I tried to slide the rear end.
  14. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Don't you have a 9-inch rear (or maybe I'm thinking of someone else)?
    When you have time, maybe you could take a measurement between the leaf and tire sidewall. 'Just curious.
    We all know about wheel backspace. I'm just wondering what the ideal (or absolutely necessary) space is between tire & leaf-spring, and tire & body.
  15. 71gold
    8" rear
