Z Bar to Hydraulic Clutch T5
Discussion in 'General Maverick/Comet' started by Aldig07, Mar 21, 2021.
  1. Aldig07
    Aldig07 Member
    Virginia Beach
    1971 Maverick Grabber
    My 71 has factory pedal and z bar for the old 3speed manual. It also has a BW T5 in it which the former owner used old model clutch fork to work with the factory zbar set up. I want to convert to a full hydraulic set up including throw out bearing for hydraulic. Do I need to change my pedal assembly ? Also, where does the clutch slave mount and does it get in the way of headers? Note- I am also changing to a tremec 5speed and it will come with the proper bell housing and throw out bearing.
  2. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    I used a Rosehill slave kit and a Wilwood master cylinder. Did my master on my own, modified my pedal for proper travel to match the master. Also cut and raised the tunnel an inch to maintain factory engine/trans angle and made my own cross member.
    https://www.rosehillperformanceparts.com/sale/63550.html
  4. dyent
    dyent Member
    vancouver bc
  5. RMiller
    Kennewick, WA
    Hadn't seen that clutch master set up, not sure how I missed it. Too late now! All I did on mine was add a little material and drill a new hole so I didn't bottom out the master at half the travel of the pedal. Thought I took pictures of it but looks like I thought wrong.
  6. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    That Modern Driveline Setup is very slick.
  7. Acornridgeman
    Wisconsin
