1972 Maverick sport lights stay on
Discussion in 'Technical' started by Mav_Max1972, Aug 25, 2019.
  1. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    And thanks for every one for helping out
  2. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    Do you got any pictures?
  3. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    I also have an ignition switch off a 74 maverick and as well the reverse switch ??? Could this effect it
  4. Craig Selvey
    Sorry....I do not have one handy.
    Mav_Max1972 likes this.
  5. William623
    Orlando
    1973 ford maverick grabber
    I don’t have a picture of one but it is behind the drivers side kick panel if I remember correctly.
  6. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    Would you know how it looks like ? In disruption
  7. Acornridgeman
    Wisconsin
    I have a couple around here someplace, but can't find them right now. Here is a pic from a different thread. Fuzzy pic but you will see what it looks like.
    Just pull off the drivers kick panel. If you have one it will be very easy to find.
    Did you try disconnecting the switch plug yet? If the switch is stuck in the on position, as soon as you disconnect it, the lights will go out.
  8. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    Yeah I took it off and they came off
  9. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    Do I just replace it
  10. Acornridgeman
    Wisconsin
    Me, I'm the kinda guy that would see if I can unstick it. Might be savable. Otherwise you would need to find one. Save the old one if it has the handle, as I often see switches for sale that are missing the handle
  11. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    So I can just replace the relay and get the sports lights working with the switch
  12. Acornridgeman
    Wisconsin
    Maybe I'm not following what you have done. When the lights are on, switch is connected, and if you pull the connection apart for the switch, the lights go out, yes? If this is all true, odds are good the relay is fine. Replace the switch and all should be fine.
  13. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    The sport lights come off only when I remove the relay not the switch. If I disconnect the switch from the contact nothing happens the lights stay on.
  14. yellow75
    Tillamook Oregon
    Then the relay is bad and stuck in the on position
    Krazy Comet and Mav_Max1972 like this.
  15. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    Where can I get another relay ?
