Hey all, 6 years ago I removed the shock towers and swapped in an RC-107 on my 1977. My plan originally was a 302-based 347 stroker but when that block ended up being bad I switched to a 351w-based 408 stroker. Fast forward to now, I got the engine and trans (c4) fully installed in the car with headers and all. Then realized there were some serious space limitations, making me think the engine sits too high. There isn’t enough clearance between the stock brake booster and the heads to install the valve cover The hood will be nowhere close to closing once I mount the carb and air cleaner Even without the above, the AC compressor hose bends will sit too high Ive attempted multiple times to call and email Rod & Customs to find out what’s going on but no one answers Does anyone happen to know if there is a difference in RC-107 kits between the 302 and 351w? thanks!
I don't know about the R&C setup, but I do know that with the stock setup, you lose an inch of hood clearence with a 351, and the stock valve covers barely clear a factory brake booster. You could convert to manual brakes, or do what a friend of mine did which was to convert to an after-market power brake setup with a smaller booster. If you want to use a high-rise intake manifold and/or a tall air cleaner, you'd have to cut a hole in the hood and put a hood scoop on...
Well, when I bought mine, they asked what engine I was going to be running and i told them a 302. Hopefully I don't have any issues but maybe the motor mount perches would be different for the 351W type motor. I've never had any issue with communicating with them. Seems odd.
I understand that but I'm saying is that maybe they build the engine mount perches on the cross member differently to compensate for the difference between a 302 and a 351 Windsor.
I guess my comment makes me look like a fool. Someone asked a question and i try to help with a solution and it gets replies like that. No wonder people leave this site.
