250 i6 running a bit rough?
Discussion in 'Technical' started by RathEmpire, Apr 6, 2017.
  1. RathEmpire
    RathEmpire Member
    Manitoba, Canada
    2008 Ford focus, 2006 Ford Ranger, 2004 Ford Focus, 1974 Ford Maverick
    hey guys, sorry to bug you again, but now that i've got the choke working right, and the idle's set where I want them (1200 for fast idle, 650-750 for curb idle) it's still running a tad rough, hopefully this video displays it well enough.
    what do you think would be causing this? Wrong setting on the idle air mix screw? Timing a bit off?
    I have the pertronix ignition so it's not a points issue. I double checked the gap for the pertronix module as well and it's bang on.
    Yes I know the muffler is ghetto, it's the one off my truck. I'm just using it on there when I work on the car in the driveway so the neighbors don't get too upset.
  2. Krazy Comet
    That's cylinders dropping out intermittently, usually a ignition issue(spark plugs, maybe wires/dist cap) but can be caused by lean idle mixture... Adjusting the mixture may help... It may just need a old fashioned Italian tune up, take it out for a good hard run...
    RathEmpire likes this.
  3. RathEmpire
    RathEmpire Member
    Manitoba, Canada
    alright i'll tinker with the idle mix screw. The plugs, wires are all brand new and I checked the plug gaps before installing.
    any suggestion on where to start on the idle mix? I've heard two different things, 1.5 turns out from seated, and 3 turns out from seated. Where should I start?I think it's around 1.5 right now. so turning it out more will richen it correct?
  4. Krazy Comet
    The v8 carbs are generally 1.5 turns out but I believe most 6cyl carbs are two to three...
    Really makes no difference, use a vacuum gage and adj for smoothest idle & highest vacuum, if necessary correct idle speed with it's adjustment...
  5. RathEmpire
    RathEmpire Member
    Manitoba, Canada
    okay cool. I'll start at 3 then, and hook the vacuum gauge up and adjust from there.
  6. Krazy Comet
    Start from where it is now... Turn it inward and if it stumbles start turning it out...
