250 trans vs 200 trans size
Discussion in 'General Maverick/Comet' started by satchelmcqueen, Apr 7, 2019.
  1. satchelmcqueen
    satchelmcqueen Member
    north georgia
    can i get some clarification on the size difference of these 2 transmissions? the reason i ask is because ive read many times that the 250 is bigger in certain ways and the tunnels on the 70 mavericks may need to be hit with a hammer to get the 250 trans to fit.
    however upon getting the 200 trans laying next to it, i did some measurements and visuals and they seem to be exactly the same in every single way. same length, height, thickness, everything. any thoughts before i waste time test fitting this later this week?
    thanks!
  2. William623
    Orlando
    1973 ford maverick grabber
    The 250 and 200 transmissions are both C4. Externally they are exactly the same except for the bellhousing which on the 250 is the same one used on the 302.
  3. William623
    Orlando
    The only time you need to massage the 70 tunnel is with the AOD.
    71gold and satchelmcqueen like this.
  4. Krazy Comet
    Dismal Swamp
    Agreed, a C4 is a C4(well almost), if they were different sizes they'd have a different ID -- C3, C6, FMX etc. There are two different styles of bell and method of mounting to case, IE pan vs case fill.
    In some applications there are different styles and lengths of tail housings, but main case is always same.
    satchelmcqueen likes this.
  5. satchelmcqueen
    north georgia
    Ok got it. I must have got confused in my memory on that aod detail. Well this makes putting it all back in a little less stressful.
  6. Craig Selvey
    Later on in the 1970 model year the Maverick also got the 250....and the trans tunnel was still the same.
  7. satchelmcqueen
    north georgia
    Got ya.
