3.55 or 3.80 gears
Discussion in 'Technical' started by JHodges, May 31, 2009.
what gears
  1. 3.55
    71.0%
  2. 3.80
    29.0%
  1. brainsboy
    brainsboy Member
    Tampa
    I agree with this too.
  2. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    What gear ratio do you think would work best for a c4 then. I was planning on putting 3.55 in mine in the near future. I have a 2800 stall converter runnin behind my 351w.
  3. baddad457
    3.27 or 3.55. The added torque of the 351 will take care of the lesser ratio in regards to the 3.27's.
  4. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Less than 3.55 with the stall converter though might not generate enough rpm for the longevity of the converter/tranny.
  6. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    The gears I am looking at are 25 spline pinion. Will that work? I thought they had to be 28.
  7. Bryant
    with the 2800 stall speed youll want 3.55s to keep the motor above the stall speed and not over heat the trans. a gear set spline is refering to the pinion spline that the yoke goes on. 28 spline is the axle spline.
  8. scooper77515
    Run the numbers through the calculators and figure out what you want to cruise at.
    I hve 3.80 and 27" tires (255/60r15). I don't mind driving the freeway at 60 mph to keep the rpms under 3000.
    I do like the quick response that I get with the 3.80, and contemplating getting a 4.11 chunk to swap out.
  9. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    Not sure if i missed the answer to wether i could use the 25 spline. By the way i know nothin about the rear end change out of gears. This goin to be my first attempt.
  10. Bryant
    you can use the 25 spline gears
  11. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    Ok thanks guys I think im on the right track now. What kinda power increase do you think I will see?
  12. Bryant
    the car will accelerat faster. if you chassie dyno it before and after you should actully see a power decrease. it has to do with the rpm range on the chassie dyno. what you will notice is its easyer to peal out, the car will be more "jumpy" when you accelerate.
  13. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    it depends on how much and what kind "street" driving your doing.I'll be moving the 8.8 with 4.11's from my mustang with a c4. it was a kick in the pants with the t5,but like the plate frame says "traction is optional"
  14. darren
    Mine has 4:11's/c4 and its an absolute riot in town. Its stupid fast through first and second gear. Bit much at 60 MPH though. This engine really likes to run around 3 grand and doesnt slob on fuel. Depends on your set up.
  15. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    My relavent experience is that I had a 100% stock 2 barrel '82 302 in a capri RS with a 4 speed. I had a 3.73 gear put in the 8.8 inch rear and I loved it. It was my daily driver for a few years @ 120 miles round trip. Caveats compared to your setup is the 4 speed will run a few hundred RPM lower at cruise speed compared to the C4. If you don't do a lot of highway driving or mind cruising the highways at 55-60, and fuel mileage is not a concern, I'd go with the 3.80 which will give you more performance under accelation. Your setup also has a little higher power RPM range then mine had.
    If you are playing at the track ... 3.80 without question.:thumbs2:
