3.55 or 3.80 gears
Discussion in 'Technical' started by JHodges, May 31, 2009.
what gears
  1. 3.55
    71.0%
  2. 3.80
    29.0%
  1. Joe Dirt
    Im using a external slave with mine.
  2. 69GT
    69GT Member
    Fresno
    72 Grabber Maverick.
    It has been so long I have a hard time remembering. I think I used the JMC Motorsports kit. It was over $400 :( But there are far cheaper ways to do it. I met a guy here locally who used to road race Mavericks and he scavenged the master and some other parts from 80s and 90s Toyota pick-up trucks. If all you need is the master and don't want to get poor like I did I'd start there.
    I also found this place. When looking around on the net :)
    http://extremecustomparts.com/i-361...jeep-cj5-cj7-cj8-muscle-cars-5-0-mustang.html
    If the rain stops maybe I'll go try to take some pics of mine.
  3. baddad457
    Where'd you put it ? With the external linkage and headers, there's no room that I can see. I've got the McCleod unit anyway from the Ranger, so that's one thing less I have to worry about fitting. I have the master from the Ranger too, just grabbed it just in case I could use it. Now I just need time to figure it all out. Might just wait til the C-4 goes first though before doing anything.
  4. Joe Dirt
    mines mounted off the trans crossmember, clears the long tube headmans on my car with plenty of room, ill see if i got any pics
  5. Streamliner
    Streamliner Member
    I once mounted a pusher slave to a fabbed up bracket to the bellhousing where it bolts to the block
  6. Joe Dirt
    i went out and took these today
  7. baddad457
    Looks like there's more room in there than I figured to be. That'll be the backup plan if I decide not to use the McCleod unit.
  8. Joe Dirt
    theres more room around the top then it looks in the pics if anything its closer to the floor board then the headers or linkages
  9. flynbrd
    flynbrd Member
    69gts uses a bolt in style and is real easy to install. You need to run a t5 bellhousing I think.
  10. baddad457
    You can't use a T-5 bell with a Toploader. Nor a Tremec (Cobra/SROD) bell. The Toploaders have a 1" shorter input shaft.
  11. 69GT
    69GT Member
    Fresno
    Yeah, the T-5 and toploader have a different bolt pattern for the trans to bell housing connection too. You can get a scatter shield with both patterns.
  12. baddad457
    No Scattersheilds for me. Too big and bulky in small cars for me. I like my space :D
