302 conversion headaches
Discussion in 'General Maverick/Comet' started by Scraperondubz, Mar 27, 2008.
  1. Scraperondubz
    Scraperondubz Member
    Oakland, California
    MAVERICK
    Not Sure, It Came With The Motor
  2. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    could be intake leak.....when you have tried everything else....might try that :Handshake
    while it is running, spray carb cleaner (I think) around the intake, if the idle changes.....you have found a leak.
  3. Scraperondubz
    Oakland, California
    MAVERICK
    The Crank Shaft Pully Has 3 Pulleys On It To Power, Power Steering Alternator And Fan.
  4. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Or starting fluid. If RPM goes up, you've found your leak. Some people say use soapy water also for the same effect, but RPM will go down with this method....
  5. Scraperondubz
    Oakland, California
    MAVERICK
    Ok I Will Check For Intake Leaks Tomorrow Afternoon As Well Along Wit Vacuums And Cab Spacer Gaskets
  6. Mavman72
    I use water,Starting fluid will tell you if you have Bad plug wires and pluck your facial hair for you.(ask me how I know:rofl2:)
  7. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    If its a stock balancer it could be way off and you have the timing too high. Just a thought.
  8. Scraperondubz
    Oakland, California
    MAVERICK
    Even If I Dial The Timing In By Ear Theres No Change, How Will The Starting Fluid Tell Me I Have Bad Plugs/wires
  9. greasemonkey
    Sedalia,MO
    Catch on fire when you hit it with fluid. Fun, and even entertaining but not reccomended.
  10. Jamie Miles
    Alto, GA
    I've had a few
    Oh man, did I ever find that out the hard way. :cry:
  11. Earl Branham
    Lugoff, SC
    Check to coil. If it is bad or weak, or the leads are on backwards, it will not run well.
  12. Scraperondubz
    Oakland, California
    MAVERICK
    Update!!!! I Changed Gaskets On Carb And Plugged Vacuums. Now It Allows We To Idle It Lower Cool!! But When I Put In Into Gear I Still Breaks Like Its Not Firing On All Cylinders And When I Get On The Gas It Like Backfires And Fire Comes Out The Carb
  13. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I would just move the distributor around till the car ran better. Screw the actual timing issue, find a sweet spot that it will run, and go from there. Always assume that everything is wrong, and nothing is right. Sounds like you have the vacuum problem solved. Troubleshoot from there, eliminating and recording your way to success.
    Dan
  14. extranjero
    extranjero Member
    PA
    Throttle linkage? I hate those head scratchers we all encounter.
  15. Scraperondubz
    Oakland, California
    MAVERICK
    Naw, Throttle Linkage Id Fine. I Replaced It With A V8 Linkage From A Mustang
