302 cyl bore ?
Discussion in 'Technical' started by mavgrab302, Dec 9, 2012.
  1. groberts101
    groberts101 Member
    Minneapolis, MN
    Combustion chamber volumes in stock heads exist within a range, due to casting tolerances. I"ve seen a little over 2cc variance from one end to the other of the same head.. so they're far from perfect to begin with. Which is of course why blueprinting some engines brings more power gain than others. Only way to know for sure is to CC 'em and then average the numbers across all chambers.
    BTW, over the years, valve jobs can sink the valves and increase chamber volume; conversely, surfacing the gasket surface area will reduce volume....lots of variables. Not to mention that the decks aren't exactly parallel either.. unless of course you spent the cash to get them that way.
    Usually most folks want to know chamber volume so they can compute CR.. and IMHO, the only accurate way of computing SCR is to quantify all volumes with a large syringe or CC'ing buret. Even the type and heat range of spark plug used has a slight bearing on this equation.
    When in doubt, go for the high side of the spec....most likely it'll be closer to reality.
    PS.. there are some thinner head gaskets out there as well and can be well worth the money of the engine is tuned for the increase in CR.
    And I'm with baddad on the 1.94 valves for milder street based builds since they give slighlty better response and less shrouding on small bore motors.
  2. mavgrab302
    Ok so the 194 valve heads it is... I just got a quote from a local machine shop... $650 dollars to build my 30 over short block....
  3. baddad457
    What are they giving you for that $650 ?
  4. groberts101
    groberts101 Member
    Minneapolis, MN
    very good question above.
    IMHO, that seems a bit steep if it's purely the cost for the machine work and putting it together. Unless of course it includes plugs/bearings/seals and is nearly fully blueprinted afterwards.. in which case I'd actually be leary of such a low price.
  5. mavgrab302
    I will get the details when I go see them... so far I know, hot tank the block and clean it up, bore it 30 over and install new pistons and rings... Also new cam and main bearings,freeze plugs....
  6. rthomas771
    Am I the only one on this forum that doesn't add the over-bore to the cubic inch displacment? To me...a 302 + 0.030 is still a 302 that had to have the cylinders cleaned up. Now if you stroked the crank...then I can see adding more numbers to the cubic inch displacment. I'm not trying to step on anybody's toes but I'm the guy who doesn't call a Tracion-Loc a Posi or a Rack and Pinion kit a Mustang II front end
  7. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Boring the block adds to the cubic inch displacement (however slightly).
    It's just a fact of life.
    My engine is a 306, like it or not.
  9. cougargt
    cougargt Member
    I think we would always say it was a punched out 302. But then again I do come form Dearborn.
  10. Krazy Comet
    Dismal Swamp
    Agreed, go the drag strip and tell them it's a 306 & 99% will know exactly what it is... You guys that are going to the trouble to say it's a 302 punched .030 over, need to hang with a more knowledgeable crowd...
    BTW River Rouge never cast the first small block :D
  11. Dave B
    You are the only one.
    I like telling people I have a 306, some people have no idea...you should see the look on their face.
  12. baddad457
    Well, here's something for you to ponder: I've got Chevy "327" fender emblems gracing either side of my Boss 9 hood scoop. A 331 is simply a .030 over 327. Same stroke, same (std) bore for both. I get very few questions now-a-days regarding the emblems, seems the liter designation has taken hold after 30 years of use. I guess I could just call it a 5.4 Tripower instead of 5.4 Triton ;)
  13. baddad457
    That's not a bad price then, considering a factory reman usually costs more, but does that price include the parts ? Or just the labor ?
  14. mavgrab302
    That price is parts and labor, assembled short block...
  15. Acornridgeman
    Wisconsin
    That seems like a great price to me .............. :bouncy:
