302 swap Help please
Discussion in 'Parts Interchange' started by Llamaface, Nov 11, 2015.
  1. Llamaface
    Llamaface Member
    1973 ford maverick
    got everything hooked up. When I turn the ignition she rumbles. When I let go, the car shuts off. What did I do wrong?
  2. Mavman72
    Explain "Rumbles" please...
  3. Llamaface
    Llamaface Member
    1973 ford maverick
    Starter turns, gas ignites, smoke from exhaust. Once the key is let loose, it shuts off
  4. Mavman72
    Sounds like the ignition switch on the column is not adjusted properly. Its on the column under the dash...
  5. bmcdaniel
    Did you have the wires off of the starter solenoid?
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Before you dive into the column, was it running before the swap? If it was, I doubt that's the issue and would look to the solenoid as others have suggested.
  7. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    One more thing to check is the resistor wire in the ignition harness I had this go on a Ford pickup and the truck would start and run with the key in the run position but shut off when the key returned to the run position!
    A early 1970's ford with an factory tach will do the same thing if the tach burns out, the tach is wired in a series
    and if it burns out it brakes the series!
