302 timing cover help
Discussion in 'Technical' started by elliot, Mar 17, 2005.
  1. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    Worked like a charm thanks alot Old Guy :bananaman .
  2. elliot
    elliot Member
    Boubon MO
    I got the dual roller on it just a short while ago. I`m gonna try to have it all done by tomorrow after noon because my mother is wanting to go pick up the new boat she just got :bouncy: .
  3. jim_barbier
    jim_barbier Member
    atlanta ga
    nice to see a dual roller with a fuel pump converting a 90 5.0 to carburation and didnt know if it was going to work everything is lining up but you never know, fuel pump roller cam piece ect.) but anyway i was going to tell you if you have it unbolted from pan and block use a block of wood to knock it if using pry bar be carefull have busted many ford timingchain covers(being aluminum). atleast you didnt break any bolts off I hope broke 1 waterpump and 1 intake right at the water inlet on the project i am on right now and didnt want to heli coil them got luucky and got them ok peace and good luck
    Jim
  4. elliot
    elliot Member
    Boubon MO
    I broke a water pump bolt off into the timing cover myself . I just put some extra rtv gasket maker in that place , so far its not leaking :) .
