351-w Is Going In!!!!
Discussion in 'General Maverick/Comet' started by htr701, Jun 24, 2007.
  1. htr701
    htr701 Mavericker
    Bradenton, Fl
  2. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Oil pan only from what I see. You will also need a pick-up tube for oil pump, Check locally an try to get a "matched set"
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Good point.
    You found the correct pan, but you need a pickup too.
    Didn't think about that detail.
    I wonder if a 302 car pickup would work? (just thinking aloud)
    You could probably buy the pickup at Advance or AZ.
