351C swap
Discussion in 'Technical' started by 1970mavinator, Nov 18, 2006.
  1. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    i think any V8 in a mav/comet will scream , power to weight ratio is thru the roof
  2. eddie1975
    Martinsburg, WV
    sold
    what do you have in the 75 now?
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    No track time.
    Like I mentioned, it was BONE stock internally, and pretty tired too.
    I did the swap because I was told it wouldn't fit.
    Drivability was the last thing on my mind.
    It had a wide ratio toploader with 4.11 gears and 25" tall tires...
    It drove like a dumptruck!
    The rpms rose so fast, too fast for the stock engine, and you would have to shift every 10 feet!
    So, no, it didn't do well, but only because it was not well executed.
    I saw a stock 67 Mustang coupe run 11.00 flat with a rebuilt 351c...
    He put it back together as a nice stock rebuild, and added a top notch Holley carb with headers and small solid cam.
    He got one run in at the track, and tech sent him packing because he didn't have ANY safety on his car required for that speed.
    FYI, the 70 model 4v was the gold standard for the Clevelands. (not counting the Boss)
  4. 70351C
    70351C Member
    Colorado
    Yes sir it is. I have the 1970 4v 58.66 cc quenched chamber heads with close to 11:1 compression ratio. I am doing a full roller cam and lifters with about a 550 lift and roller rockers. Stock those cleveland put out 300hp and 400 tq so with all that done to it and a nasty intake I think I can get close to 400-450 hp and 500 tq. all that in a 2500 pound car is going to be SCARY. I can wait!-Andrew
  5. eddie1975
    Martinsburg, WV
    sold
    did you do anything to the heads? i would port them , open the already big heads up at least smooth them out:yup:
  6. eddie1975
    Martinsburg, WV
    sold
    hey andrew is that a race car or street car?
  7. maverickdvm
    maverickdvm Member
    Michigan
    My C4 holds up just fine to the 351C in my '70 Maverick. It is a fairly stock motor and it will run 12.60s all day. It has 2V stock heads. It has been a great easy combination. The stock towers are notched and you can change spark plugs without taking off the valve covers. We are going to freshen up the motor this winter and hopefully not upset the apple cart too bad. I am going to put one in another Maverick next year.
  8. ratio411
    ratio411 Member
    Pensacola
    On 4v Clevelands, you want to do very little.
    You can port the exhaust, however you should do NOTHING on the bottom of the port at the header. Just smooth the short side.
    Widen the exhaust port only far enough to smooth out the sharp transitions, then raise the port as far as practical... far enough to take out the port roof bump.
    On the intake, you should do nothing at all for street use.
  9. eddie1975
    Martinsburg, WV
    sold
    alright dont mind me:D didnt know they were that good
    man its got me thinking next engine MAY be a C
  10. 70351C
    70351C Member
    Colorado
    Didnt port them but I just spent 650 bucks on machine work, got the crank polished, block cleaned, new freeze plugs, new cam bearings, heads resurfaced, new valve seats, new intake valves, vavle job, cylinder reglaze, and heads cleaned. It tore my pocket apart but it was worth it... looks brand new. This is going to be a street car and taken to the strip every once in awhile.
  11. eddie1975
    Martinsburg, WV
    sold
    looking good, should be a FUN street car:D
  12. 1970mavinator
    1970mavinator Member
    Ruskin, FL
    1970 2dr I6 maverick
  13. eddie1975
    Martinsburg, WV
    sold
    id be careful ording that off of ebay its not for a maverick, prolly goin to have to mod the crossmember , not sure though
  14. 1970mavinator
    Ruskin, FL
    O trust me I wasnt going to order it, remember I am on a very tight budget I was just trying to get an idea of what you guys were talking about! lol see the thing is, I originally wanted to keep the six but it has many problems now, not to keep me off the road but I have exhaust leak many slow oil leaks, blowby, transmission slipping and I believe vacuum leaks somewhere. Now I was trying to find out what would be cheaper, rebuilding the motor and tranny I have now, or buying this 351c and tranny that I found for $250? I just need to do something cheap so I can keep this car as my daily drive.
  15. eddie1975
    Martinsburg, WV
    sold
    decent price though if it works pretty good
