Already hit my first brick wall with Duraspark swap...
Discussion in 'Technical' started by Jamie Miles, Jul 7, 2005.
  1. Mavaholic
    Those oil pump shafts can be frustrating. I have a 77 250 dist in my 71 170. They are all the same. Next time get it to where it stops, then grab to fan and slightly turn the motor. Works great every time.
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    WTG! (y)
  3. Earl Branham
    Lugoff, SC
    Good job, Jamie! Sometimes patience can get you a long way!
  4. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    On my 351w, I just touch a screw driver to the solenoid to bump the starter motor while holding down on the dist. Falls right in every time.
    Good score Jamie/
    clint
  5. stmanser
    Davenport, Iowa
    you know those screw drivers that have a magnetic end and you put the screw bits into it...i use one of those (minus the screw bit) if its the small oil pump shaft it will fit right over it...turn the oil pump shaft 1/16 of a turn until the dist drops in place
  6. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    You can get a remote starter switch from Summit for about $10 (if I remember right) which is basically a pair of jumper wires and a button. While more expensive than a screwdriver, the leads are pretty long and you can bump the starter without standing over the solonoid.
  7. Jamie Miles
    Alto, GA
    I've had a few
  8. MiteeMaverick
    MiteeMaverick Senior Member
    Jonesboro, AR
    1987 Mustang GT Convertible
    clean looking install, I used a 4 prong trailer connector for a wiring harness when I did mine.....good job, now get that Fram filter off of there ! :huh:
  9. Rick Book
    Rick Book Member
    Thailand
    Nice write-up, Jamie.
  10. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Folks, this is a seventeen year old kid. If his exploits don't ring your bell, your clapper is broke.:bananaman
  11. Jamie Miles
    Alto, GA
    I've had a few
    Terry, you still looking for that trunk lid? If so, I know where you can get one or several. :)
    I thought long and hard about buying you one yesterday, and I would have, but I didn't have anything to tie my trunk lid down with since the other trunk lid would have been sticking out. :huh:
  12. Burlap1
    Burlap1 fat lazy truckdriver
    Urbana ny-wine country finger lakes wines are best
    1983 f-150 4wd,1971 cougar parts car,1973 maverick parts car,1970 maverick formerly a gramma's grocery getter,1984 f-250 460 powered,1976 f-350 u-haul,and some chevy's
    A pat on the back for you jamie!!!!
