ANYONE use Suspension King rear springs?
Discussion in 'General Maverick/Comet' started by 71maverick361, Dec 20, 2015.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    Thank you, I ordered up the same springs and was wondering how they will look installed, are they stiff?
  2. mojo
    My
    My car sit lower on the drivers side. I have new springs and shocks, all 4 corners. It is not that noticeable unless, ur looking really close. Was a while b4 I noticed it. I have seen a small percentage of these cars w/ this issue. Don't know why this is the case and really not that concerned any more. The car drives good, and not going to sweat it. No telling what wud need to be done to correct it. Just want to let u know " ur not alone". If that's any consulation....
  3. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    Thanks for the input hope I can correct it or overlook it also
  4. x72COMETx
    x72COMETx Member
    Vallejo CA
    Mine has a slight lean to it as well
  5. HiPoMavric
    HiPoMavric Member
    Aberdeen, Md
    !973 Ford Maverick
    I think it could be because the fuel tank sits off center to the drivers side of the car.
    Does it measure different when its low on fuel?
  6. x72COMETx
    x72COMETx Member
    Vallejo CA
    Got my springs they look good can't wait for some dry weather to install them
  7. 71maverick361
    Odem
    71 Grabber
    Yeah I am swapping springs around in am and see what that looks like. Also it has like over 1/2 a tank so I will check it at empty also. May put a 1/4" spacer block on RH side and see what it looks like also
  8. 71maverick361
    Odem
    71 Grabber
    Also ordered my KYB shocks all 4 and a shirt for 106$ shipped
  9. WA8DDN
    WA8DDN Member
    Malvern, Ohio
    '74 Grabber, 302,C4,3:80 to 1 Traction lock. 1973 V8 car,LDO
    I have the stock springs on my '74. The distance from floor to center of fender well is:
    Left front - 24"
    Right front - 24 3/8"
    Left rear - 26'
    Right rear - 26 1/4" Maverick, Fall 2013 035.jpg
  10. 71maverick361
    Odem
    71 Grabber
    Great looking Mav ! What size wheels you have on rear?
  11. WA8DDN
    WA8DDN Member
    Malvern, Ohio
    I think that they are 245-60-14. I think the front is 215-60-14.
  12. x72COMETx
    x72COMETx Member
    Vallejo CA
    Just got my springs installed and I love them, mine are at 27 1/2 from ground to middle fender on both sides with 235/60/14s on the rear
  13. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    Make sure the tire inflation is identical between the driver and passenger side of the car for the front set and rear set of tires. That will affect the measurement.
    MD
  14. x72COMETx
    x72COMETx Member
    Vallejo CA
    What about the front coils could one be sagging more then the other?
  15. 71maverick361
    Odem
    71 Grabber
    Same measurement on both front sides
