Brake problems Help!!!!!
Discussion in 'Technical' started by Tim Wilmoth, Mar 14, 2005.
  1. Tim Wilmoth
    Tim Wilmoth Member
    Southside Va.
    1972 Comet gt
    Folks I need a little help here. Last Spring I noticed my Master Cyclinder was leaking so I put one I had gotten from the prev.owner on it. Well as time went on the pedal started getting tighter when you drove it for any length of time to the point of vibration by the time to put the car up. So sunday I figured Bad Mc so went and got another and put it on. Felt good So lets cruise around and I thought all was fine till I got it home and I noticed front wheels were tight. Maybe the proportioning Valve or anybody else have any Ideas. I have never seen anything like this before. :huh:
    Thanks for any ideas anybody may have Oh and its manual drums stock.
    Tim
  2. Mercurycruizers
    Venetia, PA
    Sounds like you might have restrictions in the front brake hoses. It's not letting the fluid travel back to the master. Which in turn, makes the wheels tighter, cuz it can't release the shoes.....In other words, your brakes are on all the time. Just a thought......
  3. Mavaholic
    What do you mean, the pedal is getting tighter? Takes more foot pressure to stop the car? If so, could be brakes are fading because the shoes are too tight and they are over heating. That could be caused by a number of reasons. Could be brake hoses collasping and not letting pressure ease when you let off the brakes. Could be brake shoes adjustments are not working correctly. Just cause the mc is new, dont mean its good. There's no way the proportioning valve can cause the problems your having. It just turns on the brake light should one side fail.
  4. Tim Wilmoth
    Tim Wilmoth Member
    Southside Va.
    1972 Comet gt
    Hey Dennis i mean the pedal is tight as in the wheels will actually lock up. After it sits for a while it releases.I will have to pull the front wheels and check the hoses. I was gonna replace them anyway so maybe its time. I was just wondering if it could be the valve but sounds as if its the hoses Huh? Thanks Tim
  5. 73comet289
    73comet289 New Member
    Toledo Ohio
    73 comet 200 3spd
    open bleeders see if they free up. also check free play at master
  6. waynes fords
    waynes fords Member
    fayetteville,Georgia
    1973 grabber,2004 ford dually,2000 gulfstream motorhome,2003 ford expedition,66 mustang gt
    if your hoses are old they can swell up internally, kind of like arteries getting blocked,they are reletively inexpensive and should be changed every few years if your car sits for long periods of time. Or maybe they just need changing and never have been, many people don't know but most newer shop manuels say to change brake fluid every 3 years and keep it fresh. good luck!
  7. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Tim,
    Did you switch to silicone brake fluid by chance? I have been
    told not to switch to silicone from standard DOT fluid without
    changing everything.
    Seth
  8. Tim Wilmoth
    Tim Wilmoth Member
    Southside Va.
    1972 Comet gt
    Hey Seth
    Nope no silicone. Hoses are probably bad, Will try that I guess.
  9. Tim Wilmoth
    Tim Wilmoth Member
    Southside Va.
    1972 Comet gt
    Hey Folks
    Went by Napa today and ordered new front hoses and Jacked up car and put it on stands. Pulled the wheels and hit the pedal and it doesnt release . So i let off bleeder and they released. Gonna try the hoses and I have new wheel cyclinders i am putting on also . Wish me luck .
    Tim
  10. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Tim, I was going to mention the wheel cylinders. Good luck and keep us posted.
    Dan
  11. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    tim i hope all is better with the car. silly question... why not go to disc brakes? an easy swap and after driving my mavs with drums and did the switch... all i can say is wow! safer for you AND your car.
  12. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    brakes
    How old are the brake shoe springs? They are what makes the shoes pull back in. Is the brake pedal returning to where it should be? Might be holding a little pressure on the master cylinder. Also for testing, start working your way back to the master cylinder bleeding pressure to see where it stops at.
  13. stmanser
    Davenport, Iowa
    check to see if the drums are hot..... if not its a brake line or master cylinder problem
  14. bmcdaniel
    There's a residual pressure valve built into the MC port, supposed to keep about 10 psi on the wheel cylinders to keep them from leaking at the seals. Maybe it's not working right, holding too much pressure in the lines.
  15. Tim Wilmoth
    Tim Wilmoth Member
    Southside Va.
    1972 Comet gt
    Thanks for the help fellas. I put new hoses and wheel cyclinders on Friday and put about 50 miles today with no problems. Keeping my fingers crossed.
