C4 Selector Shaft & Arm position
Discussion in 'Transmissions' started by revatoons, Oct 12, 2018.
  1. revatoons
    revatoons Member
    Venezuela
    Maverick 74
    Hi, My maverick have 1974 ford c4 with column shifter I need to know in which position the selector arm should be in the park position, pointing up or down...?
  2. Hotrock
    Munroe Falls, Ohio
    I assume you are asking about the shift lever on the transmission? If that is so, the shift lever should be pointing down. Adjust the linkage with the transmission and gear selector in both the park and low positions.
  3. Krazy Comet
    Dismal Swamp
    I had to go look.
    In park, lever on my column C4 points slightly down(maybe 8:30-ish), I assume in 1st it's close to 6:00. Forgot the key.
  4. baddad457
    Down and I always adjusted it in neutral. A floor shifter C4 would be pointed up.
  5. revatoons
    revatoons Member
    Venezuela
    Maverick 74
    Thanks friends!!!!!
