Caltracs Pro's and Con's Your answer?
Discussion in 'General Maverick/Comet' started by bossmav, Jun 1, 2004.
  1. fordman
    fordman Member
    lufkin texas
    1972 maverick
    (bossmav heres my thread) they sent me a 4 piston drag brakes for a 72 maverick they said the two piston would roll with a line lock i got it all bolted on i put the hub on and had no adjustment on the bearings they were cut to deep in the hub i ran out of thread sent them back(at my expense because thats the way ford is) they made a spacer put in behind the race that worker just fine be sure to check the deph on the race in the hub & spindel you have i have the stock 72 drum spindle & hub ( 20 lb brakes& spindle) the disk brake spindle has more weight on them (45lb with brakes & spindel) the AEROSPACE BRAKES are amazing they have no drag on them when you take the brake off and the set is only 15 lb YOU WILL LOVE THEM but this may save you time and $$$ (y)
  2. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    Thanks Ivey for all the great info!
    Looks like I've got more money to spend on my money pit:)
    Terry
  3. fordman
    fordman Member
    lufkin texas
    1972 maverick
    yes i did weld the angle to the back of bars and up to the inside frame they came with a small ear on them that bent they were in the stock location i have the two shocks in back of axle i can send more pictures when i can get the car out side the shop its raining here and its to dark in the shop if you need them
  4. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Yes ,That would be helpful ,I appreciate you going to the trouble to do that for me. Thanks alot :)
  5. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    As far as weight goes, there is not much (if any) difference in weight between a disc brake spindle and a drum spindle........How could a disc brake spindle weigh 20 lbs. more then a drum spindle??????
    Just a little FYI for those interested in these brakes, I noticed at the track that ALOT of the Outlaw 10.5" cars are running these very same brakes. They run 4.40's to 4.60's at 140+mph.........they must be good brakes!!!!(y)
    Fordman, what kind of strut rods are you running??
  6. M.A.V.
    Macon,Georgia
    Yep, I spotted those strange looking strut rods too. I`ve never seen anything like them.
  7. bossmav
    Harrisonburg, Va
    These cars look more like show then drag! How do you guys keep them so clean, my drag car not as clean as ANY showen in this thread.
    Bossmav
  8. CometGT1974
    Western NC
    74 Comet GT
    I can tell you one thing, my car is DEFINITELY not a show car!!!! Yes, it may be shiny but i've got dings and dents all over the place......the suspension stuff just looks good because I had just put a fresh coat of paint on it...now it's all dinged up from where I set the alignment. Gotta remember, i've only been drag racing mine regularly for three seasons now.....before that I would just go to the drags on ocassion.....
  9. fordman
    fordman Member
    lufkin texas
    1972 maverick
    the stock 5 lug desc brake has 20 lb on the stock 4 lug drum brake thats the spindle and all so when you go to disc brakes you add 40 lb to the car the disc spindle is heavy duty because of the bolt holes put in them for the calipers ARE you saying the mustang brakes work on the maverick the struts have no bushing just rod ends with alum rods
  10. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    More pics of Ivy's set up.
  11. Rick Book
    Rick Book Member
    Thailand
    Last but not least (and one of my favorites):
  12. CometGT1974
    Western NC
    74 Comet GT
    Oh, I see what you're saying.....yes, the stock disc brake setup is VERY HEAVY!! I was glad to get rid of it!!
    The kit that Aerospace sent to me was actually a kit for the early mustangs....can't remember which years exactly but i'll try to find my invoice and see what year mustang it was....
    I like those strut rods, they are really trick looking and i'm sure they helped with weight transfer !! I installed a similar type setup using stock strut rods this past winter, it uses an aircraft spherical bearing that mounts in place of the stock bushing.....
    No doubt, your car is sweeeeeet!!!!(y)
  13. Lentech
    Lentech Member
    Ontario , Canada
    71 Mav
    Letech Suspension pic
    Sorry , File wouldn't load , we'll try tomorrow
  14. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Need to fix those pics, Lentech, so we can see 'em.
  15. Lentech
    Lentech Member
    Ontario , Canada
    71 Mav
    Pics?
    Sorry , the file wouln't load
    I'll try again soon as I get some help from someone who knows computers better than I !!!!
