CARBURETOR selector
Discussion in 'Technical' started by PINKY, Dec 28, 2008.
  1. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I agree with it too....I told you at the GATHERING you needed to go bigger :)
    *It suggested a few for my application....I like this one:
    https://www.holley.com/applications/CarburetorSelector/0-80514-1
  2. baddad457
    That formula is simply a tool to get you close to the right size carb. It by no means tells you the optimum size carb your engine will like best.
  3. Scotty P
    Scotty P Member
    santa rosa, ca
    Hmm, I am under-carbed. so they say...
  4. 74merc
    74merc computer nerd
    1974 Comet
    Pretty close. I started with a 600 CFM Holley, ran a 750 VS for a while, went to a 4100 600CFM and she loves it.
    Never looking back.
  5. 71gold
    ...same here...my 302 had a 600 CFM Holley...when i built my...roller Motor...i went with a 650 DP...it was "too" lean on the dyno.
    i got a 750 CFM and it was still "too" lean. :hmmm:
    i set up another dyno run at a diff. place and asked him what carb. he wanted to start with..."600 CFM Holley"...:yup: we did 2 pulls and he pulled it off and started playing with the air bleeds...too rich.
    i had to get an adj. metering block so we could lean it out...:yup:
    ...the 650/750 were so big they couldn't pull any fuel...:yup:
    my new moter he built...he suggested the 600 i have on it now and we will fatten it up...(y)
    ...as we know...all engines are diff....
    ... :chirp:...
  6. PaulS
    Yup! bigger carbs will run leaner than small carbs but the car may have better mixture control with a slightly bigger carb where your engine is making its power. You just have to tune it more than you would a smaller carb. No easy answers but good guidelines.
  7. baddad457
    Increasing jet size isn't a way to overcome an undercarbed condition. That only increased the fuel to air ratio, making it run richer.
