Different length z-bar frame pivot, 6 vs V8?
Discussion in 'Technical' started by bmcdaniel, Apr 29, 2010.
  1. bmcdaniel
    Anyone know, or can measure, if there's a difference in length between the frame-side z-bar pivots used in 6 cylinder and V8 applications? This would be the distance between the mounting holes and the stud.
    Thirty-six years ago when I swapped from the original six banger to a V8 you couldn't find V8 frame stands, dealers couldn't get them and they were too new to find in junk yards. Instead I have been using taller '66 Mustang motor mounts bolted directly to the frame horns since then with the original 6 cylinder z-bar frame pivot bracket, aligning the engine block and frame z-bar pivots to locate the engine. This winter I decided to install the "correct" V8 frame and motor mounts. These moved my engine 1/2" forward and the z-bar is now at an angle instead of perpendicular to the engine and frame. So I'm wondering if there was a different length frame-side bracket used for the V8?
  2. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I've had both brackets and there is a difference. I cannot remember which is further forward though.
  3. bmcdaniel
    Anyone else?
  4. spork1o1
    spork1o1 Member
    Michigan
    The V8 frame side is longer than the 170/200 I6. don't know about the 250 I6 as it uses the same bell housing as the V8.
  5. bmcdaniel
    Thanks, mine was from a 200. This would explain my problem.
