dizzy install
Discussion in 'Technical' started by newtoford, May 7, 2008.
  1. newtoford
    newtoford Member
    New Castle Delaware
    yea thats the one. hopefully this thing will be moving at a little bit diffrent pace then the ol' sixer was getting
  2. blugene
    Not familure with the terms used here. E? Is that for Edelbrock? Also, is the 303 a solid lifter style cam? I have a Competition 292 and when I got it, the next one up was a solid. Thanks in advance for sharing...
  3. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
  4. mavron 70
    mavron 70 Member
    R.I.
    1970 maverick 5.0 t 5 trans 59 ford rear with 4.11 cogs
    could use new springs with mine..traditionally a good small ford cam favors the exhaust side a little more, on the low end it's a little sluggish...but over 2grand and it gets goin....and I have 4.11s...they claim this cam is a good supercharger cam..
  5. blugene
  6. newtoford
    newtoford Member
    New Castle Delaware
    well the dizzy slid right in. was having trouble getting the oil pump shaft up into it but it all worked out. the timing marks on the gears are lined up and the dizzy is right on #1
  7. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Well ... did it start ... you made sure #1 was on compression stroke right? :)
  8. Mavman72
    If the marks on the timing gears are lined up properly(cam gear mark at 6 O'clock crank gear at 12 O'clock),its at TDC on compression stroke.
  9. newtoford
    newtoford Member
    New Castle Delaware
    if the timing gears are lined up doesnt that mean TDC on compression? but no i didnt :)
    and as for starting, we're not quite there yet ;)
  10. dmhines
    Cumming, GA
    Oh ... I missed the part where you can still see the timing marks on the gears ... guess you aren't ready to start it up ... :)
  11. blugene
    Unless he has it on one of those neet stands where he can start it, he still needs to get it into the car. I noticed the empty bay in the pic of the dizzy...
    I personaly like getting the motor in with out the stuff I can put on after...
