Does these Rims fit
Discussion in 'General Maverick/Comet' started by Whiplash, Jul 5, 2017.
  1. Whiplash
    Whiplash Member
    Alabama
    1970 ford Maverick
    Wonder if these rims would fit my 1970 ford maverick 4 lug
  2. Acornridgeman
    Wisconsin
    Well, the lug is the right size, and the offset is neutral so backspacing to the leaf springs and tie rods should be fine at 3.5" - I guess the wild card is what tire would you put on a 17" rim? That might be where the clearance problem will be.
    Static likes this.
  3. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    I think the 35 denotes offset in mm, which would give this wheel a 4.8in backspace.
  4. Acornridgeman
    Wisconsin
    Oh, that would be different. I thought (on my small screen) it was 3.5 so I figured inches.
    That would be too much backspace for most Mavericks.
  5. Whiplash
    Whiplash Member
    Alabama
    1970 ford Maverick
    So these will not fit
  6. Whiplash
    Whiplash Member
    Alabama
    1970 ford Maverick
    I need some help picking rims because every time I find some I like the numbers are off in some Way or another
  7. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    They will fit with the right spacer but if you go that route, buy good spacers and be safe.
  8. rthomas771
    Ford 4-lug wheels are 4 x 4.5"...or 4 x 114.3. Why does it say 100 is 4.5"?
  9. Whiplash
    Whiplash Member
    Alabama
    1970 ford Maverick
    Could you gents post me some links of some nice rims for the maverick.
  10. Maverocket
    Northwest
    That's kind of a personal preference thing. Do you have a certain look your going for?
  11. Maverocket
    Northwest
  12. Whiplash
    Whiplash Member
    Alabama
    1970 ford Maverick
    I'm open to all options. When I look for them only ones I see are the crager style rims
  13. Whiplash
    Whiplash Member
    Alabama
    1970 ford Maverick
    Definitely want to upgrade from these. I don't know if it's because of the rims or because the tires are so small
  14. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Here you go.
  15. Whiplash
    Whiplash Member
    Alabama
    1970 ford Maverick
    Where's the link to look and buy
